Au SEMA auto show de 1999 , GM avait présenté la TANDEM 2000 , un concept de commuter car a consommation très économique et deux place...
Cela ne vous rappelle pas quelque chose? ...
Et bien curieusement ce concept car inclus une multitude de pièces d'origine GM provenant de la Camaro, Firebird et de la Corvette....mais aussi de la Fiero.
Pièces de Suspension et console intérieure...
Dommage je n'ai pas de photo de l'intérieur...mais voici en gros la fiche technique et la photo de la voiture:
Citation: | FROM THE VAULT: CHEVROLET TANDEM 2000 MAKES ITS DEBUT AT SEMA, 20 YEARS LATER
LAS VEGAS—With apologies to the Beatles: It was 20 years ago today, we built a concept car at Chevrolet. It’s been going in and out of style, but it’s guaranteed to raise a smile.
The Tandem 2000 presents an exciting opportunity to get inside the heads of concept car designers and engineers from two decades ago—and to get inside one of their products. In the late 1970s, the world was in the throes of an energy crisis, and GM’s Research and Design Staff developed the Tandem 2000 as an experimental exercise in lightweight, low-cost, high-mileage, commuter vehicles. With some radical styling thrown in for an exotic touch.
The Tandem 2000, which is its original name so it seems appropriate to finally take the wraps off it as the millennium nears, was conceived as a low-cost street version of a Formula One Grand Prix car. After its creation it did the focus group tour, and has been updated periodically over the years, but has never before appeared in public until the 1999 SEMA show.
The seats are 1985 Corvette. The exterior mirrors are 1985 Camaro and Firebird. The dashboard and shifter assembly are Fiero. Much of its suspension parts are Fiero—other bits are handmade, as are some of the interior panels.
So it shares some parts, but the Tandem 2000 was a unique application. It’s a rear-engined two-seater that stands just over four feet tall on a 114.7-inch wheelbase and weighs just 2478 pounds. Its steel-tube frame is handmade and buffeted by six crossmembers, with bending and torsion estimates placed at well above 30 Hz.
The Tandem is powered by a 2.0-liter four from GM’s previous J-cars, mated to a fuel-sipping three-speed automatic. The small 10-gallon fuel tank is located in front of the engine behind the rear seat.
The concept car is distinguished by its dark blue, one-piece fiberglass body shell, with two hatches for people and one rear hatch for the engine. If anything, it was the radical bodystyle of the Tandem 2000 that led some customer clinics to produce love-it-or-hate-it reactions.
But a look back from the fresh perspective of a new millennium shows that Tandem 2000 was clearly a car and an idea ahead of its time. At the very least, there’s a lot to learn from such a vehicle, both in its own era’s context and in today’s context as well. Plus it’s fun to roll it out onto the show floor after all these years.
This is one toy that appeals to the fast kids and the smart kids.
Tandem 2000
VEHICLE DIMENSION
* Overall Height- 48.8 in.
* Overall Width- 58.8 in.
* Wheel Base- 114.7 in.
* Track- 59.8 in.
* Overall Length- 175in.
* Ground Clearance-5.5 in.
WEIGHT
Curb weight: 2428 lbs.
Weight distribution: 61% front/39% rear
* LF- 464 lbs.
* RF- 453 lbs.
* LR- 758 lbs.
* RR- 753 lbs.
TIRES
* GOODYEAR P245/50/ZR 16 Eagle GSC
BATTERY
* 12-volt system mounted in left rear quarter
FRONT SUSPENSION
* SLA with hand-made lower tube arms with rod ends
* Upper arm, hand-made combination rocker to coil-over-shock
* Springs are coil-over-shock, Koni unit
* Spindles are Fiero
* Stabilizer bar is off the end of rocker with links, 0.5" diameter
* No rubber furnishings
STEERING
* Rack-and-pinion aftermarket, non-power
* Column is Fiero
* Steering wheel is Corvette (no air bag)
REAR SUSPENSION
* SLA with Fiero lower arm and cradle assemble
* Upper arm is hand-made combination rocker
* Spring is coil-over, Koni unit
* No rear stabilizer bar
* Spindle is Fiero
BRAKES
* 9.5" front and rear disc
* Single-piston calipers
* Power brake booster, vacuum operated
FRAME
* Hand-made from 2" x 4" x .125 square steel tubing
* Front and rear sub frame made from 2" x 2" x .125 steel tubing
* 2 large major cross members
* 4 small cross members
* Estimate that bending and torsion is above 30 HZ
* No bumper structure
HVAC
* HVAC and heater unit in nose of vehicle
* Condenser is located in right rear quarter
* Compressor is mounted low on front of engine
COOLING
* Radiator is 18" x 22"; mounted in right rear quarter
* Single 12" electric fan
ENGINE
* 2.0 Liter four-cylinder (J-car)
* Mid-engine location
* No EGR
* Holley 2-bbl carburetor
* Aftermarket CD ignition
* Oil filter is remote mounted in left rear quarter
* Engine mount is typical transverse with upper dog bone to the rear
TRANSMISSION
* THM 125 3-speed automatic
EXHAUST
* 1.5" headers into single 3" collector to muffler and tail pipe
* No catalytic converter
FUEL SYSTEM
* 10-gallon fuel tank
* Tank is located in front of engine and behind rear seat
BODY
* One-piece fiberglass
* Dark blue exterior color
* Two side-hinged hatches for entry/exit
* Rear hatch for engine
* Floor is .075 sheet aluminum
* Outside mirrors from 1985 F-car
INTERIOR
* Hand-made panels, carpet and trim
* Seats are 1985 Corvette
* Dash is Fiero
* Shifter assembly is Fiero
* No audio system
LIGHTING
* Rear tail lights are Corvette
* Front head lamps are 2" x 3" (4 total) |
_________________ Long hairs never goes out of style !!!! Hard Rockin '80s!!! |
