Jeu Fév 21, 2008 8:00 pm |
Sujet du message: ~~ Computerizing The Fiero ~~ (Laptop & Touch Screen) |
Mister Pegase de Plastique
Inscrit le: 19 Jan 2007 Messages: 118 Localisation: Calgary, Alberta
Sam Fév 23, 2008 8:19 pm |
fierogt88 Pegase de Plastique
Inscrit le: 14 Jan 2007 Messages: 167 Localisation: Sherbrooke, Canada
When you finish thats you'll do mine......
Great job Mister !!!!! _________________
Sam Fév 23, 2008 8:55 pm |
really nice
j en veut un aussi
Mer Fév 27, 2008 10:50 am |
Sujet du message: Sweet upgrade. |
Dimeadozen Pegase de Plastique
Thats so amazing. So you used an IBM computer to basically run all the functions possible in a car? I suppose you can run music, movies, and get crazy quality out of it. PLus can U run diagnostics using the computer by reading straight out of the ecm? U should put a plexiglass cover over it and lights underneath to glow it up at night. Thats a crazy upgrade though man. Nice work. ONe of a kind truly, never seen that done before the way you did it. Props. |
Mer Mar 05, 2008 11:37 am |
Here is today's update:
http://www.fiero.nl/forum/Forum1/HTML/069619-2.html#p73
Did more work on it.
If you're interested there is more interesting info on P.2
fierogt88 a écrit: | When you finish thats you'll do mine......
Great job Mister !!!!! |
Thanks
Dimeadozen a écrit: | Thats so amazing. So you used an IBM computer to basically run all the functions possible in a car? I suppose you can run music, movies, and get crazy quality out of it. PLus can U run diagnostics using the computer by reading straight out of the ecm? U should put a plexiglass cover over it and lights underneath to glow it up at night. Thats a crazy upgrade though man. Nice work. ONe of a kind truly, never seen that done before the way you did it. Props. |
Thanks Dimeadozen,
As for the "crazy quality" -
- There are still ground (-) problems to eliminate with the head unit radio
- The laptop itself produces electronic noises on the audio output
- I would get an external USB sound card, that should bring the audio quality up to par.
For the ECM diagnostics - I haven't plugged in the serial ALDL cable yet.
From my experience, I do scanning with a helper with me and he holds the laptop out and does the scanning.
For the LED lights - My Fiero concept is to try and keep things as close as possible to stock. This is why everything is hidden away when not in use.
It's still a daily driver and I have to think of safety too
BigBen a écrit: | really nice j en veut un aussi Ben |
LOL... |
Sam Mar 08, 2008 6:15 pm |
Its awesome. No worries, I think if grounding is your only issue, you are not that far set back the ground cable u prolly know should be always as short as possible, so since the equipment is between the seat, cant you just ground it under the upholstry? or even tap it into the firewall?
I totally agree with the stock look. when i finish mine its interior is gonna more or less be stock too, but i really wanna trick out the body. if it was like my old notchy i'd leave the bod, but the Gt begs some modern upgrades. i'm thinkin go with a new bumper, remove the spoiler, add side scoops, some hella lights and lambo doors. i'll be happy then. _________________ A hammer is an Auto Mechanic's best friend |
